Icons
Aeris Calendar: Tech support, suggestions, discussion, etc.
Mewling Moy
Icons
Post by Mewling Moy »
Any possibility of new icons for events, specifically ones related to money?
Would be nice for keeping track of bills, taxes, recurring payments, etc.
Re: Icons
Welcome to the Esumsoft Forums, Mewling Moy!
Thank you for your inquiry & suggestion. Jeff will be responding further to you when he next drops by the Forums.
In the interim, as you are our newest member The Esumsoft Team requests that you please review the following Sticky:
The article provides important information which all members need to be aware of. If you should have any questions or comments, please feel free to let us know.
Welcome aboard! :)
Re: Icons
That's an excellent suggestion, I've added that to my notes.
You can add your own icons. You can add icons under:
...\Aeris Calendar\Images\Events\
And you can place the image into an existing category (folder), or create a new category (by creating a new folder).
The png format is usually recommended, and I would resize the graphic if the source is excessively large, as it will just use more resources to down-sample it. Something in the range of 32x32 - 64x64 should be good (but a lot depends on other factors like your resolution). For comparison, most icons in Aeris v2 are 32x32, but I've been using 64x64 for icons added to Aeris v3.
Let us know if you have any questions.
Mewling Moy
Re: Icons
Thanks, I'll give it a shot.
