Old messages
tjpsnj
Old messages
Post by tjpsnj »
Most of my accounts are yahoo or gmail IMAP.
The oldest mail is not all in the accounts I have in Poppeeper. Some matches the web logged in account exactly.
Is there a way to go back and retrieve all the messages back to the beginning of the account?
In addition I would like to retrieve folders if it doesn't modify how the poppeeper interface looks and feels.
Thanks,
TJP
Re: Old messages
POP Peeper will retrieve all the messages in the folder by default, but the number can be restricted. Check under Tools / Options / Message retrieval, or for per-account setting, edit the account and check under the "advanced" page (if it's not there, enable "advanced options" under main menu: Tools / Options / General).
Another possibility is that the message you're looking for is hidden (ie. filtered as junk or other reasons), so you may want to temporarily disable main menu: Messages / Enable display filters.
As for accessing folders -- this requires either Pro or the Plus Pack and the interface won't change -- folders are added just like regular accounts.
