POP Peeper v5.1 released
POP Peeper v5.1 is now available for download:
There are some notable changes in v5.1:
- Oauth2 is available for AOL
- Oauth2 for Yahoo defaults to using your web browser instead of the internal browser
- Oauth2 is updated for Outlook; this may work for organizations which use Outlook for IMAP
- Web of Trust has been removed due to policy changes on WOT's end (WOT is no longer a free API); it has been replaced by a "Trusted Sites" plugin, which is simply a user-defined list of sites that *you* trust (with some common domains safe-listed)
Re: POP Peeper v5.1 released
Known issues:
- If the Windows System text size ("Make text bigger") is used (e.g. 125%), then the message/account lists may overlap the statusbar and other buttons below the lists. * this is not the same as the Windows DPI setting ("make everything bigger"), which is not known to cause this issue.
