Change Messages Font
Moshe
Post by Moshe »
Using a custom Windows 10 theme, I've been able to change the default font to "Tahoma" NonAntialiased.
Would it be possible to force IE 11 to display messages (in PP) in a NonAntialiased font/quality? - I really don't like ClearType.
Thank you.
Re: Change Messages Font
Not any supported method. You can take a look at this potential solution:
https://superuser.com/questions/506192/ ... -windows-7
These solutions are old, though, and only mention Win7 (although one comment mentions it does *not* work on win8.1, so...), but you can change PP's IE-emulation under:
main menu: Tools / PPtweaker / Troubleshooting
Be aware that modifying IE may cause some of your emails (newsletters, most commonly) to not display correctly. So if it doesn't work, be sure to reset that.
Moshe
Post by Moshe »
Hello Jeff,
Unfortunately neither has worked.
Thank you. I appreciate it.
