Hotmail Send Mail failure
Hi, my main Hotmail account just refused to send an email to my wife's Hotmail account - log attached - no recent changes to anything on my side that would cause this. I can login in on their website. Thanks
- Attachments
- 240220 Hotmail Send mail failure.txt
- (897 Bytes) Downloaded 340 times
Re: Hotmail Send Mail failure
There are a few such examples in the wild about this error (and specific to Outlook/smtp), but the OP never seemed to follow-up, which might suggest that the error cleared up on its own. "Account locked" seems ominous; "contact administrator" sounds like it's for non-free addresses -- is your account a standard hotmail account (ie. @hotmail.com or @outlook.com)?
- Are you still able to retrieve mail via POP Peeper?
- Did you try sending an email after logging into the website?
- You might try using Oauth2 in POP Peeper -- edit the account and to the right of your "login name", change the dropdown to "Oauth2" and then follow the instructions.
Other examples of same error:
https://learn.microsoft.com/en-us/answe ... tp-account
https://learn.microsoft.com/en-us/answe ... unt-locked
The account is still retrieving mail in Pop Peeper
I can send email from the website
This is a standard Hotmail account
I gave up on Oauth2 for Hotmail awhile back, at your suggestion, I think
It never sent the original email, but I just deleted it and re-created it - the second one seems to have sent
