I have modifed a skin to fit in with my desktop. I need some help to get new message number to show in the right position.
In the first pic you see that they fit perfectly in the circle(Green Arrow).
In the second pic when you have one digit it does not sit in the middle of the circle as shown in pic 3. How can I get single digits to sit in the middle.
Pic 1
Pic 2
Pic 3
Here is the code
Code: Select all
[INFO]
Skin_Name = Simple
Skin_Info = Simple
Skin_Author = Alpha F. Laurent
Skin_Mail =
Skin_Web = http://www.poppeeper.com/
Skin_Dim = 60 x 60
[CONSTANTS]
_TYPE_Window = 0
_TYPE_Button = 1
_TYPE_Editbox = 2
_TYPE_Static = 3
_IDOK = 1
_IDCANCEL = 2
_CMD_OPENPP = 10
_CMD_CLIENT = 11
_CMD_DISMISS = 12
_CMD_RELOADSKIN = 25
[VARIABLES]
%NumNewMsg% = number of new messages
[MAIN]
BmpTrans = 128 0 127
Slider_Enabled = 1
Slider_Speed = 3
Slider_Timer = 25
Slider_Delay = 3
# - Define some global defaults
FontName = Arial
FontColor = 180 150 200
FontSize = 12
[sNewMessageNumDisplay]
Type = _TYPE_Static
Pos = 10 15
Size = 150 200
Label = %NumNewMsg%
FontName = Arial
FontColor = 104 104 104
FontSize = 12
FontBold = 1
