Minor visual bug in View Message window
ppuser
Post by ppuser »
- Open PP
- In the list of mails, doubleclick on a mail with at least 1 attachment
- When the window opens, mouse-over "Attached" combobox
- After that, mouse-over "To", "From" and the other fields (the fields, not their respective labels) but do not go to "Attached" again.
- See that the "Attached" combobox's upper line has disappeared, as if another control (probably the "To" field) has been placed over it.
This happens under Win10 latest version, fully updated with the default theme at 100%. It's not the latest version's issue, it has been happening for quite some time now.
Re: Minor visual bug in View Message window
Until I actually did it, I wasn't quite sure what you meant, so I've made a screenshot to better show what's happening:
The red dot on the right side shows the problem -- you can see that the top-line of the border for the attachment box is cut-off. Presumably this is from the "To" field obscuring it.
Incidentally, a change I made for the future-v6 already addressed this problem (even though it wasn't specifically for this).
ppuser
Post by ppuser »
Jeff wrote: Wed Jul 24, 2024 2:49 pmThe red dot on the right side shows the problem -- you can see that the top-line of the border for the attachment box is cut-off. Presumably this is from the "To" field obscuring it.
Yup, that's it...
Jeff wrote: Wed Jul 24, 2024 2:49 pmIncidentally, a change I made for the future-v6 already addressed this problem (even though it wasn't specifically for this).
Unfortunately i was a little lazy to report it earlier (before the release of 5.5.3), so i missed my chance to have it corrected...
Well, i'll just have to wait for 6.0 then. :)
Just try to ignore it till then and don't let it drive you insane :mrgreen:
Of course, now that you've pointed it out, I'll probably start poking at it like a bad hangnail.
ppuser
Post by ppuser »
Well, i have been living with it for quite some time now, so i'll try to constrain myself. Hopefully v6 will be released before i go nuts and start running around, screaming! :D
