POP Peeper v5.4.1 (public release)
POP Peeper v5.4.1 is now available for everyone. If you have Pro or the Plus Pack, you can use auto-update; go to Help / About and press the "Check Version" button to update immediately. You can also download the install files from the Download page.
Notable changes since the last public release (v5.2) include:
- Oauth2 support for POP3 (Gmail, Yahoo, AOL)
- “Prior unread” has been added as an available view-message toolbar button and an option for delete action; note: “prior” is used instead of “previous” for width considerations
- Configuration files added for @verizon.net and updated for AT&T-based domains
- Plus Pack: Sent Mail Viewer adds keyboard shortcuts to access the Message/Account/Folder lists (Ctrl+1, Ctrl+2, Ctrl+3) as there was no other way to access these lists via keyboard
You can see the full version history here: https://www.esumsoft.com/pop-peeper/versionhistory/
Re: POP Peeper v5.4.1 (public release)
The Plus Pack has just been updated to v5.4.1 (it was previously v5.4.0). This fixes a problem with the voice notifier playing if the "voice notifier enabled" setting was disabled; voice notifier would not play if the voice notifier plugin was disabled (as expected).
