Is there any way we can ADD more user flags? In addition to the 5 provided?
If yes, please guide how.
More User Flags?
Re: More User Flags?
Yes, additional User Flags can be added or you can also modify existing User Flags as well.
Take a look here on the esumsoft website for details on how to do this: https://www.esumsoft.com/pop-peeper/ref ... #userflags.
And you may also want to look at more advanced features regarding User Flags: https://www.esumsoft.com/pop-peeper/ref ... ser-flags/.
Keep in mind, you can also always utilize POP Peepers "Help" by way of the POP Peeper main menu to get information on this by going to "Help", "Contents...". At that point if your on the "Contents" tab then expand on "General Information" in the "Contents" list (click the "+" to do this) and select "User Flags" for detailed Help. (or you can also select the "Index" and/or "Search" tabs instead of using the "Contents" tab and type in "User Flags" in either case as well.)
Thanks a lot for this prompt response and resolution. Really appreciated!
You're very welcome, if you have any further questions - don't hesitate to ask.
