Moved to Folders
drummond52
Moved to Folders
Post by drummond52 »
I moved some emails to a folder, how do I see and open the folder.
drummond
Re: Moved to Folders
You can view other folders with a Plus Pack and/or Pro license. Note that either license allows you to *view* the messages, although Pro provides more capabilities to *manage* the messages (e.g. moving messages between folders).
Instructions for adding a folder are here:
https://www.esumsoft.com/pop-peeper/faq/?q=aop_folders
I might also mention that there's an extremely good chance that a new method of accessing folders will be added in v6.0.
drummond52
Thank you very much, managed to get it figured out with the help of the tutorial.
drummond
Brianwuz
Post by Brianwuz »
The OP's question was never answered on how to view the messages. The link was for crating folders not viewing. I used the move to option and selected add folder which came out as INBOX.folder1, INBOX.folder2 etc and moved messages to these folders. How do I access these moved messages now? I do have the Plus Pack and the Pro.
Thnks,
Brianwuz
After moving the messages (you wanted moved) to the new folders you created - have you done a "Check Mail" (see screen-shot below) to populate the folder list with the new folders and messages moved to the new folders for the selected account?
Clicking on the "Check Mail" button will populate the new folders in your folder lis that you have moved the  messages to.
FOLDER LIST - CHECK MAIL.png (5.35 KiB) Viewed 4 times
Once this is done you can then read (access) the messages in the new folders by selecting the respective folder in the folder list.
