Custom Toolbar
This page lists the command IDs that you can use for creating custom toolbar buttons.
There are two sections:
Main ID reference
Message ID reference
ID Reference: Main toolbar
ID (Main)Description
114 | Open a message that was saved to a file, usually with a .eml extension |
32794 | Toggles AutoCheck; whether POP Peeper will automatically check for mail |
115 | Open the error overview window |
33143 | View the list of messages that are currently saved to “Draft” |
33023 | Open the Sent Mail Viewer and open the “Archive” messages for the selected account |
33302 | Open the Sent Mail Viewer and open the “Deleted” messages for the selected account |
33424 | Open the Sent Mail Viewer and open the “Junk” messages for the selected account |
32906 | Open Windows Explorer and open the “Sent” folder for the selected account |
33014 | Open Windows Explorer and open the “Archive” folder for the selected account |
33303 | Open Windows Explorer and open the “Deleted” folder for the selected account |
32832 | Toggle the toolbar on/off (or, just “off” since you can’t press this button if the toolbar isn’t shown) |
32830 | Toggle if text is shown on the toolbar |
32833 | Customize the toolbar |
1081 | Accounts: Add/New |
1079 | Accounts: Edit |
1080 | Accounts: Delete |
32850 | Accounts: Edit the columns for the Account list |
32851 | Accounts: Select the font that the Account list uses |
32841 | Accounts: Toggle the “Enabled” checkbox displayed in the Accounts List |
32837 | Accounts: Reset the width of the Account list to the default |
32985 | Messages: Toggle whether hidden messages are shown |
32852 | Messages: Edit the columns for the Message list |
32853 | Messages: Select the font that the Message list uses |
32950 | Send Mail: Forward as attachment |
32952 | Send Mail: Edit as new |
32875 | Send Mail: Send all messages in the outbox |
32831 | Options: Open the Main Options |
32829 | Options: Set Admin password |
32854 | Options: Run PPtweaker |
32981 | Options: Run Backup/Restore |
33018 | Options: Open the Activation window |
32866 | Options: Open the Plugins |
32949 | Skin Notifier: Open the Skin Notifier settings |
33148 | Voice Notifier: Open the Voice Notifier settings |
329 | Voice Notifier: Stop the current voice |
33116 | AntiJunk: Open the AntiJunk settings |
32836 | Help: Open the Online Help website |
32896 | Help: Open the general website |
32897 | Help: Open the online FAQ |
32898 | Help: Donate |
10 | Help: Open the About window |
1049 | Selected message: Open Message Source |
33027 | Selected message: Open message in HTML |
33028 | Selected message: Open message in Rich text |
33029 | Selected message: Open message in Plain text |
32900 | Selected message: Add sender to Address Book |
32865 | Selected message: Remove message from list |
32820 | Selected message: Display information |
32984 | Selected message: Toggle hidden |
32842 | Select all messages |
n/a | n/a |
32780 | Selected account: Check mail Note: for Selected account commands, no action will occur if no accounts are selected. Selected accounts are accounts which are highlighted in the Accounts List. |
32781 | Selected account: Check stats |
32783 | Selected account: Check headers |
32878 | Selected account: Check preview |
32879 | Selected account: Check entire |
32817 | Selected account: Disconnect |
33015 | Selected account: Duplicate |
32838 | Selected account: Unlock password protection |
33025 | Selected account: Archive messages |
32797 | Selected account: Remove messages |
32824 | Selected account: Clear WebMail cookies |
32777 | Selected account: Display server info |
32990 | AntiJunk: Blacklist email address for the selected message(s) |
32991 | AntiJunk: Blacklist email address domain for the selected message(s) |
32992 | AntiJunk: Whitelist email address for the selected message(s) |
32993 | AntiJunk: Whitelist email address domain for the selected message(s) |
33300 | AntiJunk: Display evaluation info for the selected message |
33007 | AntiJunk: Re-evaluate the selected message(s) |
32995 | AntiJunk: Test selected message in sandbox |
32989 | AntiJunk: Delete junk |
ID Reference: Message toolbar
ID (Message)Description
1049 | View message source |
57636 | Find in text |
33098 | Find next |
33099 | Find previous |
32895 | Toggle the default encoding |
33008 | Send Mail: Forward as attachment |
32951 | Send Mail: Edit as new |
32984 | Toggle the message as hidden |
32857 | Open options for “View message” |
32828 | Select the font that will be used for Plain and Rich text |
33039 | HTML font size: Largest |
33040 | HTML font size: Larger |
33041 | HTML font size: Medium |
33042 | HTML font size: Smaller |
33043 | HTML font size: Smallest |
32900 | Address Book: Add sender |
33122 | Web of Trust: Summary (deprecated) |
32858 | Help: Message |
32864 | Help: Virus prevention |
33423 | Open message in client |
